T6 on 20's ACC ?
Pau1GTI
Good evening chaps,
Quick one, my van is booked in to activate the ACC on Saturday.
I've came across a few posts regarding potential ACC errors and bigger wheels
I'm currently on my winter 17s so won't be able to try my 20's on after the activation for at least another month. So don't want to get it done and find out later it's going be an issue.
My 20's are staggered 8.5" front with 245/45/20 and a 10" 275/40/20 rear
Has anyone tired this setup with ACC ?
Good evening chaps,
We have done loads with this spec . perfect .
By 'activate ACC' do you mean you're having adaptve cruise control coded in because your van didn't have it prior? If so do you need a seperate button installing to activate it? A new steerng wheel with the acc button? Is it an expensive job? Looking forward to hearing how it turns out and if you feel it was worth it.
Yes that's correct, new steering wheel buttons. £420 plus vat from Professional Retrofits 👍
From experience, the issues are usually with the T6.1 variant, rather than a T6.
There is a difference in wheel speed measured by ABS, compared with the speed measured by the assist camera near the rear view mirror.
