Have you found this out?Hi. On a similar theme, I’ve got a 2017 Kombi with a captains chair for the driver and then a double bench next to the driver. I want to remove the double passenger seats and replace with a matching captains chair for the front passenger. Is that as straight forward as it sounds, same fixtures, in the right place? And can I fit a swivel to the new seat simply? Thanks in advance.
Are there any bench seats with airbag in them? I thought the bench doesn't come with an airbag. In case I get one with airbag, this might be a problem since disconnecting that airbag when removing the bench will trigger a fault.Swapping bench to single is easy! Took me about 30 minutes but no integral seat air bag or heating element.
1) the 4 surplus studs unscrew out of the floor - 2 end up on show (holes in the rubber mat). Bungs available on ebay circa £12
2) Double to single - no
3) Mine was 9 seats and dropping to 8 saved £1K on insurance. I just had to send V5 to DVLA amending seat capacity
4) Single seats are expensive. I think I paid £490 for a basic seat and got a pittance for the 600 mile bench seat!
Hope that helps
Ian
Ian, I do have one other question.Swapping bench to single is easy! Took me about 30 minutes but no integral seat air bag or heating element.
Hope that helps
Ian
Thanks Ian. Good idea with the UK drivers seat, will look into the bases for the two.Mine has the axillary heater in the rear and air con in the front. Last week we were out on a v hot day and with the air con on and rear fan on blow (temp set to coldest) it soon got the temp down to a comfortable level for the four of us. The rear fan just helped circulate the air better. I've never really investigated how the rear system gets its heat - if its piped air from the front then it could well be linked to the air con too. If it has a water filled radiator then I doubt its linked to the AC.
I think it is the shuttle (Velle & Cali) that has the proper rear air con with overhead vents.
Re seat you might be better looking for a UK drivers seat - could be cheaper? May need to check the bases are interchangeable. There is also a place in Poland that sells seats on ebay.
Regards
Ian
