T6 T32 180 limp mode
Hannu
I'm sorry to say that I'm very much old school and a VCDS novice.
I've just returned from a run were everything was fine and then after about 1/2hr returned to the vehicle to find the engine management light on. I connected VCDS to find the following warning:-
2 Faults Found:
9120 - EGR Sensor 1
P046C 00 [11101101] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 216700 km
Date: 2102.14.31
Time: 18:05:32
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 68 C
Intake air temperature: 13 C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.080 V
Unlearning counter according OBD: 40
Air mass: actual value (mg/stroke): 0.0 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 100.00 %
EGR Solen.val.: actual value: 99.82 %
EGR valve: offset closed: -10.21 %
Actuator for high pressure EGR: status-Bits 0-7: 0
Actuator for high pressure EGR: status-Bits 0-7: 55
High press EGR actuator: actual unconditioned volt val: 1311.6 mV
11866 - Position Sensor for Turbo Inlet Valve
P22D5 00 [01100000] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Believing this was nothing major "implausible signal" I cleared the fault only to find the vehicle in limp mode.
I'm I right to clear the code to see if it returns and how do I get it out of limp ¯\_(ツ)_/¯
Many thanks
2 Faults Found:
9120 - EGR Sensor 1
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 216700 km
Date: 2102.14.31
Time: 18:05:32
Many thanks
Forgot to mention its a CFCA engine
Please share
1) full VCDS Auto-Scan​
2) engine blockmap data - ignition ON, engine OFF​
3) engine blockmap data - engine running at idle​
How-to:
VCDS > Applications > Controller Channel Map >
For "Single controller address" - 01
Tick/fill boxes as above and click Go.
VCDS flashes screens for a moment (when finished hit "Done, Go Back") and there should be a file blockmap-01-... in folder C:\Ross-Tech\VCDS\Logs\....
Note: only VCDS HEX-V2 and VCDS HEX-NET cables have the capability to create blockmap files.
Please share
How-to:
Wednesday,18,December,2024,13:56:02:63135
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
Many thanks for your assistance
I'll carry out the other check in the morning, I'm currently thinking I'll be needing a EGR value and cooler
Bryan
  • Log-YK16WPE-WV1ZZZ7HZGH078729-134659.txt
Reactions: mmi
Please share
How-to:
Sincerely hope this makes more sense to you than it does to me
  • blockmap-01-03L-906-019-HK_WV1ZZZ7HZGH078729-20241218-2053.csv
Reactions: mmi
Thank you!
Could you please make also one but: ignition ON, engine not running.
Would help to understand how things are "at rest" as the fault P046C was triggered when engine was not running
Freeze Frame:
Meanwhile, have a look into VCDS if CFCA engine also have same diagnostics functions available as T6 EU6 engines - I believe it has as the diagnostics functions have been in ECUs "forever".
EDIT: it seems that in CFCA engine data has different labels.
Thus the following data items (measurement values) need to be "ticked" for CFCA engine's EGR testing:
  • IDE00473 EGR Vacuum Regulator Solen.val.: activation
  • IDE00581 EGR specified value
  • IDE01259 EGR Solen.val.: actual value
  • IDE01373 EGR valve: offset closed
  • IDE01374 EGR valve: offset open
  • IDE04257 High pressure EGR actuator: activation -9.23 %
  • IDE04259 High press EGR actuator: actual unconditioned volt val
Yes, clearing the codes should take it out of limp mode.
Thank you!
Good morning, it didn't save the ignition on engine off data yesterday ¯\_(ツ)_/¯. I'm afraid I don't feel confident enough to do the further EGR test, always afraid of changing something I shouldn't and cocking things up.
Clearing the fault code HAS NOT taking it out of limp mode . Looking very much like I'll have to bite the bullet and change the EGR value and cooler
Many thanks for your help
  • blockmap-01-03L-906-019-HK_WV1ZZZ7HZGH078729-20241219-0833.csv
Reactions: mmi
Thanks for sharing the data - appreciated. Presumably sticking valve would only be noticed by doing a longer (than just one sample). recording. The procedure shouldn't change anything but never checked on CFCA engine - so indeed better safe than sorry.
Interesting - possibly the implausible signal value was captured already when doing startup preparations.
New EGR + cooler sounds like a plan - obvioulsy sooner than later. Please update with new blockmaps with new parts.
Will do, parts on order
Reactions: mmi
