Removed from my 2018 T6 T32 at 50k miles. In good condition as seen in the pictures. Only reason for removal is that I fitted coilovers to lower the van.
This is a complete suspension set, excluding the front top mounts/bump stops and rear lower spring seat rubbers, as I re-used these. They're easily obtained if you can't re-use them from your existing suspension though.
I'm after £175. Collection preferred from Chandler's Ford, SO53. I'd consider posting them at cost, I expect this would be £30-40 or so considering the weight.
This will only fit T32 vans.
