Amazing what you can find in here!!I have a complete set, taken off my 2018 when VB Air was fitted at about 10k. In Lancashire.
I probably will have something , I only keep stuff with less than 5000 miles on the rest is binned . Is it shocks and springs needed ??@CRS Performance Steve, have you got any standard T32 stuff in your workshop?
It is the full set, van is currently on coil overs so want to have everything changed out.I probably will have something , I only keep stuff with less than 5000 miles on the rest is binned . Is it shocks and springs needed ??
@Blu-Tack @Martin Gibson @Longster82 @Kingsimon2000 @louisfeakes @Trouts
all have some that they’re looking to offload, if any of them live nearer.
Whereabouts are you? What year van are they off and how many miles had they done?Lincolnshire - Full set of T32 shocks and springs.
Yes a full set , If you have coil over s you might need the Bump stops and dust covers as well I should have some of these as well as the rear rubber mountsIt is the full set, van is currently on coil overs so want to have everything changed out.
