T6 TPMS and ESP lights on and can’t be reset.
Adam_scfc
I’m hoping someone can help me, I have a T6 shuttle on a 65 plate, I have the esp light and TPMS light flashing whenever I turn the vehicle over, took it to VW specialist who said they are unsure what it is as the plug up just tells them it’s a databus malfunction and so the systems aren’t talking correctly but they are unsure as to why.
Has anyone had a similar issue?
Vehicle drives fine, just worried as it won’t pass MOT with the lights on and it’s also irritating having it binging and bonging at me whenever I get in it.
Please note I have tried resetting TPMS and I just get a message saying that it is unable to store tyre pressures.
Also tried disabling the ESP but this doesn’t resolve the issue either.
At my wits end with it and hoping someone can help.
Thanks in advance.
It sounds like a broken wheel speed sensor, cheap and simple to fix but you need to find out which one. Get yourself a Carista dongle and scan for errors. The garage you went to doesn’t sound much of a VW specialist.
I have a Carista, what am I looking for on there? As mentioned when I scan I get these codes but no real info on what they mean.
I mean I’ll be honest I wasn’t convinced, they were telling me it was the squib ring because I replaced it due to an airbag fault, so I have ordered another new one to fit, but it seems to me more likely that it’s an actual sensor gone.
Also this is the data from the Carista
ECU info obtained with Carista 801099 for iOS:
Code:
VIN:
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Software version: 0736
ASAM/ODX identifier: [none]
Coding: 042305 (hex)
Fault codes:
03158 Manufacturer-specific code
Engine
Part #: 04L906056KM
Component: R4 2.0l TDI
Software version: 6186
ASAM/ODX identifier: EV_ECM20TDI03004L906056KM
Coding: 0019401C430401090000 (hex)
[No fault codes]
ABS
Part #: 7E0907379P
Component: ESC
Software version: 0132
ASAM/ODX identifier: EV_Brake1ESCCONTIVN75XGP2
Coding: 307E40982566847F0C75027BA48421D3790000 (hex)
Fault codes:
00396 Manufacturer-specific code
08324 Manufacturer-specific code
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: 01 (hex)
Fault codes:
332644 Manufacturer-specific code
Airbags
Part #: 7E0959655E
Component: VW10Airbag00C
Software version: 0016
ASAM/ODX identifier: EV_AirbaVW10BPAVW12X
Coding: 000000000000000000000000000000003043 (hex)
[No fault codes]
Instrument cluster
Part #: 7E0920970L
Component: KOMBI
Software version: 1008
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 470F010300 (hex)
Fault codes:
13654544 Manufacturer-specific code
Radio
Part #: -----------
Component: Radio
Software version: 5814
Coding: 16000440040000 (hex)
[No fault codes]
Infotainment system
[ECU not present]
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907040C
Component: ClimatronicT5
Software version: 0508
ASAM/ODX identifier: EV_ClimatronicT5
Coding: 0000000103 (hex)
[No fault codes]
Auxiliary heater
Part #: 7E0963273
Component: STH-T5GP2
Software version: 0007
ASAM/ODX identifier: EV_AuxilParkiHeateWOST5G2
Coding: 4101 (hex)
[No fault codes]
Parking/steering assist
Part #: 7E0919475K
Component: PARKHILFE 4K
Software version: 0106
ASAM/ODX identifier: EV_VW75XParkAssis4K
Coding: 108001 (hex)
[No fault codes]
Central electronics
Part #: 7E0937090
Component: BCM PQ25 Max4
Coding: A0F4793A0A613413922049642C2B8CD40D00698960444960320400BF0800 (hex)
Fault codes:
00886 Manufacturer-specific code
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 030B1A73 (hex)
[No fault codes]
Obtained with Carista 801099 for iOS.
Download app: https://itunes.apple.com/app/id954363569
Facebook: Carista
What recent work have you had done one on the van
A fair bit, new stereo aftermarket but no issue’s subsequently, new squib ring as mentioned above (due to me damaging the old one taking the steering wheel off, new DPF and all piping, new injectors, new battery. These just popped up one morning with no rhyme or reason.
Steering angle
Part #: 6R0959654
Coding: 01 (hex)
Fault codes:
Start by repairing this fault.
