T6 VCDS crank and water pump question
Bathaudio
Hey all, can I please ask for a little help on the water pump and crank sensor codes??
When starting the van I get 3 longish beeps and doesn't start that well. I can't rev beyond 2000 when in neutral which didn't use to happen.
If you know the par numbers that I need it would be massively helpful!!
Photo attached :) TIA
Coolant pump
Check wiring/plug
Check the resistance of the pump with plug removed to see if the pump is open circuit or it is the wiring to the pump.
G40 Hall sensor
Check the plug and wiring for damage, check the sensor is fixed or just replace it.
