Im reworking my van's leisure wiring atm, plan is as follows:
Im keeping pretty much the same setup as I have now (as it's working pretty well), just a few minor rework jobs:
Any more general feedback on my setup (whilst its all out)? I'd like this to be the last time I have the floor up if at all possible.
- Moving the HUP & Consumer unit
- Adding a trickle maintainer for the starter (cable may be reused in future for solar charging the starter, hence the uprated size)
- Consolidating various single fuses into a fuse box (instead of the functional but messy set of random individual load fuses my converter left)
- Conduit & mounting space for battery monitoring and solar cabling which are both on the longer term plan
- General tidy up of the cabling spaghetti whilst I have the cab out for sound deadening etc
- The 6AWG cables going into the B2B are crammed into the charger's screw joints with lots of strands not in the terminals (converter put this in.... I guess just rushed it...)
- 16mm/6AWG seems to be widely recommended for B2B systems so I guess this must be a common problem, surely just "shove it in" is not the right way....?
- The DS Load cable is terminated with a ring terminal / strip fuse that wont allow me to consolidate into the blade fuse box as the cable is too large for yellow spade connectors.
- How do people get larger cables into a blade fuse box? Does it HAVE to be midi/maxi fuses for these larger cables? I assumed blades would be ok as you can get 40A fuses in the format.
