THQ - T6 Tailgate Rear LED lights - sequential and standard indicators (I believe achievable by swapping one connection (yellow cable) on the light prior to fitting although I only used the sequential indicators)
VW Transporter T6 - Rear Lights - Sequential Indicator - LED - RHD - Tailgate - Black Smoke
In an alluring black smoke tint, these T6 rear lights really work at shining light on the rear end of your van, keeping everyone behind you in the know.
Fully operational, removed only to fit a different style of lights. £70
Can be posted using Parcelforce if required, postage paid and arranged by buyer. (Box: 66x45x17cm. 6kg)
These are the LED version and so have the LED style connector not the halogen connector. Included with the lights are the plugs required to retrofit to a tailgate van with halogen lights. The lights have fog & reverse lights in both clusters and with a small wiring modification it is possible to wire these in and have both sides working.
The plugs have pre installed tails and heat shrinkable crimp connectors to make changing the connectors easy or the pins can be removed from the existing connectors and swapped into the correct location on the new plugs as explained in the post below
Barn Door Halogen to Tailgate LED Rear Lights - pinout
I’m converting my van from barn doors to a tailgate which means I need to change my tail lights. This is how I changed mine to LED lights. Removing the lights is simply 2 screws but the wiring plug is different. You don’t need to crimp or cut any wires to make the conversion. Start my removing...
