Three times Three Beeps
HarryMay1969
Hi All
In the last week, when I turn on the ignition of my T6 diesel I get three beeps from the dash which repeat three times, there are no warning lights, and there does not appear any issues. I have search the internet and nothing and there are no errors on the OBD scanner, however this did show low voltage on the scanner so have fitted a new battery, but no change, still the nine beeps when I put in the key? Any ideas?
By the way, the alternator is also checked and working fine putting out 14.6 volts and when the engine is off the battery 12.6 volts.
All fluids are also topped up, AdBlue, brake, power steering, screen wash, oil, etc. ??????
Hello @HarryMay1969 ,
Did you find perhaps an answer to the issue?
I have a Polo 6R which beeped exactly the way you described and I cannot find any answers on the internet.
I found the source of the beeping. In my case, it was an aftermarket alarm that I installed (and did not think to check its instructions).
So, for me, it has nothing to do with the car or its battery.
Reactions: mmi
