Yes it is a channel in the leading edge, if you lift the front cover you will see the channel
see attached photo
there is another way to attach a drive away awning without using the channel - see photo #2 - note this only works when the awning is tight against the van as yiu use the casing the secure the Figure 8 strips against the main casing (provides a bit more height and is easier to fit after driving away and returning to your pitch.
Morning all, How are you good folks attaching your drive away awning rails to your van with the wind out awning attached? On my old T25 I had a channel for a figure of 8 attachment. Curious to see who is doing what on the T6
