Has anyone fitted a Thule Omnistor 6300 to their van with a Reimo Multi-rail? I like the low profile of this awning but unsure if it's suitable for a T6?
I’ve got an Omnistor and a Reimo multirail fitted to my van. The trouble is it renders the multirail useless due to the way the Omnistor is fitted to it.
I didn’t fit them, they were on the van when I bought it.
Thanks for the pictures. After a load of research I think I’m going to go with a Fiamma F40 Van awning. Mounts into the factory roof rack points and requires no drilling
Just make sure the F40 doesn’t touch the roof in the middle. Certainly earlier ones bowed in the middle and came into contact with the roof causing rubbing
Hi, I’m about to get this setup. Unfortunately I had the reimo installed before I knew what it was really for. Is it possible to remove the brackets or are they riveted to the van? Also, do you know which brackets you’re using? Thanks
