Having done a lengthy trip to central Australia I have noticed a few things about my solar setup.
I have a 150w panel permanently mounted on my roof and a 150w blanket. My battery is a 120ah agm deep cycle.
My fridge is a 80 litre dometic.
In temperatures up to 25c I can park in the sun and permanent panel will keep battery charged ok. No problems.
BUT when its really hot and interior of van gets up to 35c and higher the fridge runs almost continuously trying to get temperature inside down to set temperature.
I cant park in the sun as this makes van interior even hotter so permanent panel is not outputting. I now have to rely on my 150w blanket which in ideal conditions can add 6 to 8 amps(120w_140w) to battery but fridge compressor is using 4 to 5 (60w)of those so only small amount going back to charge battery. This means it takes a long time to recharge battery and some days can only get to 80percent or so.
If the night stays hot then fridge cycles more often and by morning I can be down to 50 percent. If day is going to be hot again same situation as above again. What if cloudy and raining next day, almost nothing back to battery.
This showed me that even though my setup copes with temperate conditions when it gets really hot for longer periods I have to do a bit of juggling to keep battery charged enough.
I guess my solution is another battery and another portable panel so van can be in shade and portable panels in the sun.
Anyone got any thoughts on this as a solution.
