Top of dash 12v socket to dual USB
baldgeezer
Anyone swapped the 12V socket on the top of the dash (centre) to a dual USB? Wondered how easy to access to do the job?
Seen a few people do this.
The hardest part is getting the OEM socket out in the first place.
The existing socket has a short wire and conector plug.
Just be mindful that USB power chargers use power all the time, so it's not recommended to connect to the starter battery feed without a switch.
Or, use an ignition feed.
Or, use a leisure battery feed.
I have a blank with no wires Dell. How tricky is it to feed the wires down to the fuses near the gearbox?
