Tow trust help
m3wood
Hi everyone
I have a tvw9 tow trust toe at fitted to my van but it’s missing the swan neck.
I’m looking everywhere to see which one I need to purchase with no luck.
Can anyone tell me if it’s an acs61 or a acs63 swan neck that I need ?
Now I’m not sure that the ACS number is the size of swan neck or not… any help would be much appreciated guys and gals.
Hi everyone
I have a tow trust tow bar, not sure what it means but the label on my swan neck is Type: ACS 63.
If you call them or email with the details of your van they could give the correct part number .
You need to end up with the ball correct height off the ground but cannot remember off hand the messurement.
I tried ringing them before and they just said about contacting a local installer to have one fitted and the number they gave me just keeps ringing out. I’m not looking to spend loads as there are loads of used ones on eBay which I’m sure one will fit. I’m hoping someone will have one fitted and have the details of the one I need
Do you have a picture ? Would be really handy. I thought the acs number was the size of the bar but I’ve since found that 1 acs 63 doesn’t seem the same shape as other acs 63 swan necks. So now I’m very confused
From a quick Google search, it appears that the ACS63 is compatible with Al-Ko stabilisers, whereas the ACS61 is not. Not sure if that helps at all though... :unsure:
So there are different shapes of swan neck and I’m not sure how you differentiate between them. Thanks for the help guys. This is getting a headache ha ha
