Towbar coding south Manchester/ Cheshire
danncus
Hi. Can anyone help me code a towbar on a 2018 T6. It had factory prep and I fitted a PF Jones rear loom.
Can easily travel during weekdays
Hi,
Just wondering what it is you need coding for?
I fitted the same to my 2019 Caravelle with factory TP and required no coding.
Matt.
If you have towbar prep then the module is already coded from the factory. No further coding is required.
There are conflicting reports, the PF Jones instructions for the rear loom say it needs to be done. I think the basic functions are there.
“Encoding VW with VCDS
Please note :
The procedure described below for encoding and enabling the trailer mode only serves for a general orientation and can vary greatly depending on the model (motorisation / equipment).
If necessary, fewer or further control units will have to be adapted.
→Encoding EZE_09 (electronic central electric controller):
Access authorisation: 31347 “
Encoding
hitch_ecu -> installed
I'm north Manchester if you want to travel that far if you have it fully fitted and isnt working as it should.
