TPMS on T6
Ush66
Can someone advise if I can swap the 18 “ wheels on my 2018 T6 (Not 6.1) without it triggering the TPMS? - looking at using the same circumference wheel with 17” steel rims & thicker tyres to give the same overall diameter.
Looking through other posts it seems to work off the abs rather than a sensor in the wheel??
Ta
I believe its a rolling radius not actual sensors. When I get a tyre change or change to my winter wheels, TPMS goes off but you just reset it to the new levels and its fine. No sensors in the wheels etc
Ta
Correct, there's no actual sensors on the T6, it just uses the rotation of the wheel via the abs sensor to measure the radius. If a wheel is spinning faster that it expects to see due being a smaller radius, thanks to a low pressure in the tyre, it throws an alert.
So when you fit the new wheels, re set the tyre pressures in the MFD and you'll be all set.
Apologies for reopening an old post.
I have a T6.1 Kombi. I’m about to take delivery of another next week. On the new one I want to stick some swamper wheels. I’m trying to work out if I need to pay the extra for the sensors in the wheels. From what I can understand the sensors are only used in direct monitoring…. I believe direct monitoring is an option extra. Neither my current van or the new one have TPMS listed as an optional extra.
Any help greatly appreciated
I can only speak for my own 6.1, which has indirect monitoring, and swamper wheels went on without hassle.
Thanks Sasquatch. I imagine they’ll be no trouble. I called the dealer, they haven’t got a clue what I’m on about. Doesn’t bode well for any future servicing and repair relationship they plan to build with me I’ll be honest.
