TravelinLite drl kit (with oem led headlights) not turning off
Keaney
Right had a lot of faffing about after having the kit for ages but waited till some carbon bits are done.
initially thought the loom from TravelinLite wasn’t working but worked out that the pins in the connectors were not pushed in enough.
all sorted and wired in as per diagram so:
Earth to battery
Red to fuse box 5amp as per instructions
Yellow to yellow and black from headlight
works fine but then turn the van off and the aftermarket drls stay on and don’t go off.
anyone had this issue before even after the courtesy lights go out
I've got those drl's and they stay on for maybe 2 minutes longer than the courtesy lights but they do eventually go out. Odd if yours stay on permanently...
Have you got your lights set to auto? Might make a difference...
Yeah set to auto… might double check then and wait longer
