Travelinlite Facelift kit issue ?
T6 LYE
Hi all, has anyone bought the Facelift 6 to 6.1 kit and do you have to do any wiring mod as I've bought their Headlights but have a couple of issues which im trying to sort.
No sidelights on front only with key removed… and rear indicators sometimes miss a flash with dash arrow flashing quicker ?
I've turned off bulb monitoring with VCDS ??
I fit standard lights on mine from travelinlite, I had to fit a diod I think it’s called between two of the wires, if you call them they’re normally really helpful, they should be able to advise you .
Thanks bud but my lights are LED and Travelinlite informed me they were plug and play…. Im still in discussion with them
I’ve since fitted transporter hq led lights , which work fine too, I’ve not changed any wiring other than the diodes as recommended by them . What rear lights do you have ? Did you change them at the same time ? Is it worth fitting your standard rears back on see if it’s something to do with the rear light wiring ?
