Travelinlite Headlight beam adjustment
GregMick
Hi all! I’ve recently fitted Travelinlite T6 Headlights with dynamic LED indicators, LED DRL, but halogen H1 & H11 bulbs. What I can’t work out is how to adjust the beam so they are level & not only lighting 2m in front of the van. Anyone fitted & adjusted these before? If so, can you post a photo of where to adjust the beams?
Thanks!
The adjustment screws are the two above dipped beam and the two to the side of the main beam lamp housings. I'm not sure which is up or down, but trial and error against a flat wall will work.
View attachment 56574 View attachment 56575
I put some labels on the top of my THQ V2s before installing to avoid trial and error or using a mirror to read lettering on the back of the casing.
There’s an existing seventy something page thread on these headlights, always worth a Search on the Forum first.
My V2’s did not require any adjustment when fitted.
