Tyre Pressure Monitoring
I’m my experience, when screws go through the looms in this way they affect more than one circuit and will usually happen instantly. Also conversion centres are very good at knowing which areas to avoid screwing into.
I can tell you 99% sure it is a simple software update of the abs control unit. I can’t go into any more details but if you contact your dealer when they open it should take around 45 mins to update.
Hi sorry for jumping in. I too suffer from tyre pressure loss indicator currently not available, it has been plugged into VW commercial diagnostic and they concluded the tyre pressures were too high. Reset pressure and fault and still fault signals intermittently. Cruise control also drops out and not fault code found.
Any assistance greatly appreciated.
