Hi all, the clear out continues.i have an unused uberbus aluminum sump guard to fit all transporters ( not sure about 4 motion). Collection from Derby DE65 6DW. Can meet relatively local
Here's some info from uberbus's website. Made from 5mm thick aluminium plate, this sump guard is designed offer protection for engine and gearbox against any impact and debris in the road or trail.
It can be fitted directly over the top of the factory plastic engine tray or as a direct replacement.
5mm Aluminium – lighter than steel and corrosion resistant
Comes complete with fitting kit including stainless steel bolts, washers and aluminium spacers.
Helps keep engine clean from dust and dirt
Reduces engine noise
Pm for more info, thanks Pete
