Had a complimentary Vehicle Check (AKA let's see what we can fleece the customer out of) at VW York today. Couple of things flagged up which Im unsure of. Was told that Undertrays were broken on both sides (approx £340 to replace both) and rear EGR pipe leaking...Anyone had issues with the under trays? For a relatively new van with no off road excursions Im a bit puzzled. Also- what's an EGR pipe?
Thanks for any info...Cheers
Had a complimentary Vehicle Check (AKA let's see what we can fleece the customer out of) at VW York today. Couple of things flagged up which Im unsure of. rear EGR pipe leaking... what's an EGR pipe?
My undertray was also flagged up as it had a bit missing. I’ve not changed it. Regards the Egr pipe mine also was leaking I could smell exhaust smells in the cab when it regenes. The new part is shaped differently to the old one which apparently helps prevent the pipe from splitting.
Resurrecting this rather than start a new one - I seem to have lost the panel(s) under the AdBlue and diesel tank - would these be 55/56/57 as per Loz's most excellent parts diagram, please? 2017 / 204 / T32
Wouldn't know the part number for 70-71 on the diagram?
Assume this is the drivers side rear panel before the bumper.. not sure if taken off mine was had different suspension fitted and forgot to put back on?? Thanks
