I have a 2019 T6 Kombi (204 DSG, twin sliders, tailgate etc) that I'm just about to start my second conversion.
My sister had our previous 2015 T5.1, and I'm going to do some things slightly differently this time, the main changes being
1. To put as much as possible under the front seats (T5.1 had double passenger seat so we left that for storage).
2. Larger output inverter (camping kettle)
3. Solar (will allow us to go a little longer when we can't get hookup), some race circuits aren't possible to get close enough to hookup
4. As before, bluetooth control for as much as possible and minimum 'stuff' to wire in/display etc
5. Front seats both on swivels
This is my current thinking, and thank you to Martyn from Travelvolts for his help so far! I'll buy all from Martyn if possible, so some of the links are to other sites and I'll update)
VERSION 1
Under bonnet
Slimline EHU to front grille (Compact EHU Connections | Hookup | Motorhome | Van Connections | UK)
Battery monitor (CTEK 40-149 Vehicle Battery Monitor: Amazon.co.uk: Car & Motorbike)
IP65 Consumer unit (Wylex 3-Module IP65 Insulated Enclosure With Visor)
Under passenger seat
Inverter (Victron 12.1200 Inverter | travelvolts)
Victron IP65 battery charger (only for leisure battery when on hookup) (VICTRON Bluesmart IP65 12/15 | travelvolts)
Under driver's seat
CTEK D250SE DCDC charger (will also have 150w solar panel, so CTEK has MPPT)
130aH battery (EXP+130 AGM battery | travelvolts)
12v Fuse box (12 way fuse box with negative rail. | travelvolts)
Victron 65a SmartProtect (eg Victron Energy Smart Battery Protect 12/24V 65A - BPR065022000 – Battery Megastore)
Heater pipes for Planar heater
Any thoughts that would make wiring easier - eg that reduce the number or gauge of the cables?
I'd love some photos / ideas for the installation under the seats - in my mind it's a super-neat installation but I need ideas to help me get to that!
Also - tips for placement under the seats would also help
VERSION 1
Under bonnet
Under driver's seat
