Unlocking pin connector for wing mirror switch
SAF1981
Diver
Hello I need to add a yellow wire to this pin block but I'm puzzled as how to release it so I can push the yellow wire all the way in to connect it?
Does anyone have the method to solve this krypton facto puzzle?
The rear edges of the plug hinge out
Insert a very small thin screwdriver into the edge of the plug where the small slit gap is and you should be able to twist/lever the edge of the plug off
