Up-grading my pop top roof
Cyclejunkie
Hi, has anyone up-graded or changed there pop top roof I have a basic pop up roof but was looking at something a bit better,mine at present does not have the built in pull down roof bed which incorporates the bed base & mattress, this would be what I’d like to upgrade to and was wondering if anyone out there has herd or knows of a company that could do the upgrade….thanks in advance
If you contact the existing roof manufacturer they should be able to advise you if you can install a bed board.
The existing hole will need to be the same as the new roof for a direct fit - unlikely however, failing that you can infill sections of panels if needed or use a different type of roof such as REIMO or SCA, which generally have a larger frame section which should (hopefully) cover the existig hole.
Rgds
Ian
