Upgrading T6 to T6.1 halogen tail lights (tailgate)
Parvus
Hi,
Looking to replace my 2018 T6 rear lights (halogen) with OEM T6.1 rear lights (halogen), does anyone know if it’s a straight swap (e.g. matching connectors, no coding etc…)?
I’m not looking for the LED conversion just a straight swap if possible.
Anyone have experience/knowledge? Tried searching but all focused on the LED upgrades.
Thanks,
Matt
Hi,
Thanks,
Matt
If you decide to do it, I've got a pair of rears only 6 weeks old.
Hi,
I changed mine to t6.1 bought them from travelinlite they come with a pin tool and instructions which wires to change over really easy to do. I should still have the instructions if your just buying the lights let me know I’ll send an image over
Thanks both, appreciate the responses. @F2JON - can you share the instructions please, would be good to check the info
@plateman - Assuming they are for a tailgate model, how much are you looking for? Drop me a private message, thanks
Hi I've seen some T6.1 tailgate lights that I'd like to fit to my T6 2018 does anyone know if they are a straight swap or is there some pins that need changing over ? does anyone have annoying diagrams I could follow? Thank you.
Hi pal, would you be so kind to share the said instructions and possibly a picture or link to the pin tool needed?
Massive thanks in advance
Hi
Could someone please forward me instructions aswell please
TIA
Paul
Hi
Want to upgrade t6 rear lights to t6.1 and understand they need re pinning,they are both halogen, would appreciate it if anyone had the wiring diagram please
TIA
Paul
Are your cables colours and connectors different to those links in post #8? Post up a pic of your wiring and connectors if your lights aren’t working
Sorry mate only just seen this post hopefully this will help anyone else doing the same conversion IMG_0347.jpeg
