The units are 510mm high, and 1270 mm long (both together) and 1100mm widethis looks great - i have a swb and want to retain the double seat as well. is the unit 1500x415mm? thanks
thanks much! i hadnt spotted the kombi kit - cheers!The units are 510mm high, and 1270 mm long (both together) and 1100mm wide
I’m looking at this VF kombi set up as we speak. I like the idea of the bench seat for day trips etc. Is it too high to sit on comfortably with the 3 inch cushions on?
Unfortunately it is, im 5'11' and my head touches the roof when im sat on the bench. The lower benches VF sell would be OK but then they would be too low for making into a bed with the kombi seats. TBH on the one camping trip we have managed to fit in when we sat in the van I used the kombi seat and now have a swivel for the passenger seat so there is less need to sit in the back. Overall im still pleased for the money spent
Just out of curiosity how much was this set? Looks top notch thatAs long as you don’t need safety inthe rear it’s fine, I needed seatbelts and isofix so Cascade was the solution.
Just bought the VF Kombi pod and I’m planning on using the lashing fixings in the floor as a point to fix to, with some additional brackets etc. Not quite worked it out yet!This also may sound like a bone question but how did you all go about fitting the units to the actual van??
Sorry to bring up an old post. But how comfortable is it to sit in those rear seats. It looks like you would have to sit twisted and so doesn't look very comfortable.As long as you don’t need safety inthe rear it’s fine, I needed seatbelts and isofix so Cascade was the solution.
Hi can I ask the height of your U-shape bed please? VF no longer do bespoke as I’d like it to be the same length on either side too so I’m going to attempt to make one but struggling to find height details anywhere. Thank youI'm now trying to find someone to cover them.. Its a nightmare finding the right fabric..
I asked vanfurniture this same question on Instagram. They replied that the bed unit height is 415mm. Not sure of cushion height. I guess about 90mm, So 500mm total height.Hi can I ask the height of your U-shape bed please? VF no longer do bespoke as I’d like it to be the same length on either side too so I’m going to attempt to make one but struggling to find height details anywhere. Thank you
Any details on how you fastened this down please?
So I’ve found that the weight of the units stop them moving about on the rubber mat (they would probably slide about on a smooth floor). The two units are bolted together which also helps stop them moving and they pushed quite tight to the middle seats. I have then fixed them to one of the tie down points by the back door. I may add further tie down points at some stageAny details on how you fastened this down please?
