@andythom188 The gap on the slider door handles should be even top and bottom, the pod fits in tight to the rubber of the door opening, and follows the indent on the door pressing at the top and sides of the door window area.
Be careful how far in you put the lip of the shade at the bottom, the clearance if it's too far out means that when the shade is down, and you open the door, the handle of the shade will rub the rear quarter. The pod will also press against the seat back upper corner as well.
Best idea is to fit the bolts in the middle of the fixing point, so that if needs you can elongate the hole in the pod to give you some in/out adjustment if needed.
Hope this helps, will try to send you some pics if you want..
