Vanstyle fog light wiring
Wrenners
I’m in the process of retro fitting some fog lights to my T6 and just after a bit of advice on the wiring connections for the titled.
As usual it didn’t have any info with it. I didn’t really want all that on off when cornering malarkey so went for the kit that is relay based with the auto light switch that has the additional front fog position on it The relay has a single (white) wire from it that obviously is the coil feed. It has a particular type end crimped on it which Im guessing/hoping (not got to that area yet) may go in to the bcm plug.
Looking at the bcm layout, is it possible to connect this relay feed into either terminal 9 or 10 on T73b and have them function via the fog switch without any further work needed? or is there additional wiring needed or coding. I’m thinking of getting obdeleven at some point so coding would hopefully be possible with this.
Probably easier to wire them as factory than mess around with aftermarket relays etc
