This post is intended as a quick reference for common alterations performed via VCDS allowing the end user to navigate straight to the desired function rather than scrolling through modules/screens to search for it, this is a working progress and will be edited/amended over the coming weeks/months
The first post contains functions changed via 'coding' and/or long code helper
The second post contains functions changed via 'adaptions'
Layout information
First Number = 'Module' Containing This Function
Second Number = Relevant 'Byte' For Function
Third Number = The 'Bit' Containing The Options For Relevant Modification
Function = System or Object Being Configured
Option/Option = Choices/Options Given
1st-2nd-3rd = Function, Option/Option
09 - 00 - 3 = Auto Unlock, On/Off
09 - 00 - 4 = Auto Lock, On/Off
09 - 01 - 7 = Locking Setup-Rear Lid Locking, Single Door/Whole Vehicle
09 - 05 - 1 = Acoustic Lock, On/Off
09 - 05 - 4 = Acoustic Unlock, On/Off
09 - 14 - 4 = Tear Wiping, On/Off
09 - 23 - 6 = DRLs, On/Off
17 - 00 - 4 = Instrument Display Country Code-Remove KPH & Add Large MPH Display, UK/Australia (More details/guide here)
5F - 04 - ** = Speaker Setup-Adding Rear Speakers, 4 speaker 2 channel/6 speaker 4 channel
If you require a full comprehensive guide for all functions and modifications a premium download is available to VIP members and lists every module fitted to T6s with details of all relevant functions and modifications
https://www.t6forum.com/downloads/categories/vw-t6-vcds-information-guides.9/
Layout information
