Hi I have been playing with my new machine, trying to work on most options, but I have quiet a few questions, so wonder if any of you can help with them all?
- LHD FOR LIGHTS I live in Spain, have a RHD van, so how can i enable it for the light to work correctly for here?
- AIR CON SETTINGS
- WHAT IS TERMINAL 15?
- Distance impulse set to eos jester etc, why not for the van?
- Country rest of world? Why does it have this setting, and what is it for?
- In 17 personalisation active, s cant see on my screen?
- Park steer assist version 3 instead of 2? Why is it set to 2, should 3 not be better?
- What is CAN gateway ?
- User interface skin 3? What is this for, and can you change displays?
- Activate voice without subscribing, is this possible through VCDS?
- Predictive route data, what is this?
- I have fitted LED driving lights, but occasionally get bulb warning failure light, is there a way to turn it off for daytime lights?
- Being in Spain, i do nt find the air con that special, are there any settings to enhance it?
- In engine section i unticked RHD as thought for light, is this correct, I did try to activate it and get options for use VCDS default Ot try values on the module, not sure what to do now!
- Can I only change values in the installation tab, are all of the other tabs not relevant?
- I previously used the Carista app, and enabled Refuel option, but now it shows but no read out, how can i fix this please?
- Can’t find option to make the n/s mirror dip when putting in recverse, could somebody please advise?
