Ran VCDS update today (first time in a while) and updated to 16.8.0
Updating to this version required the firmware in the lead to be updated also and came with a warning that it cannot be changed back so once done you can no longer use the lead with any older versions of VCDS.
I noticed a few improvements from the older version, had a scan through most of the menus and a bit more information in general it seemed and i attempted to make changes to the parking assist controller (which previous failed) and worked this time, this module requires a security code and now the code was given to me when i highlighted the text entry box which i could not do last time so hopefully things should be a bit easier now.
I didnt make that many changes today but tomorrow i intend to set tear drop wiping, auto locking amongst other things so will let you know how i get on
