Carissa or odbeleven? Looking at doing some basic programming ie auto locking etc. Would like auto mirrors but assume not available on my 16 plate shuttle se
Really helpful thanks @mmi - I searched extensively, not sure how I missed that threadOBD Eleven and Credits
Just how does the credit system work on OBD 11. How do you get credits that are worthwhile as I see some functions/apps cost 100. So How much do they cost if you have to buy them? I think you get 1 per day free, but that ain't much.www.t6forum.comOBD Eleven and Credits
Same as most of my ideas I think about it but don't actually get around to it until a few months later.did you get this sorted? im in carterto/witney with VCDS
For fault finding Carista is just a code reader - but unfortunately not even a good one for that purpose.Carista or Obd Eleven for general use and fault finding
Great post. I would love to learn how to get more from my vcds. Are there any websites, as well as the ross tech forum i could use to help? Thanks.For fault finding Carista is just a code reader - but unfortunately not even a good one for that purpose.
E.g. here
Carista acc not available
Hi, yesterday I got acc not available and front assist not available when I started my van. This also resulted in no cruise control My carista didn't list any faults (not to do with acc anyway!) But I did find the square box on the bumper loose (appeared to have popped of a balljoint) so I...www.t6forum.com
Would you consider VCDS? For fault finding it's capabilities are superior - besides just fault code reading it has the capability to do realtime measurements & recordings for further and analysis.
E.g. below a VCDS screen capture of a multichannel recording about EGR valve self-calibration.
Or captured data can be processed even further in spreadsheet
[T6_measured] 01-Engine - Oil pressure switches & Oil level sensor
For future reference. Applicable to T6 EU6 engines. Oil pressure switch - F1. Switch pressure 2.3 to 3.0 bar Oil pressure switch for reduced oil pressure - F378 (919-040) Oil pressure regulating valve N428 (906-030) References: Workshop Manual Transporter 2016- Engines: CXFA, CXGA, CXGB...www.t6forum.comWon’t start [Resolved]
T6 204 diesel. Van was used on a long drive and then a trip to the shops. It was left 5 mins and then wouldn’t start. Turns over but doesn’t fire. no fault codes. There was a slight burning smell when I parked up and it looks as if the front egr pipe has a crack, rear one has already been...www.t6forum.com
