Hi, I need to remove my starter battery and want to know what problems might occur when replacing it. I've seen that I may need to reset the one touch window procedure lowering down then up again other than that is there anything else I may need to reset? the battery will probably be disconnected for 1 to 2 hours.
The reason for removing the battery is because I'm planning feed cables through the firewall behind the battery. I have an Ecoflow Detlta 2 battery for camping and have the Ecoflow alternator charger for it so need to connect the alternator charger directly to the starter battery but need to remove the battery to get the cables through from inside the vehicle to the battery compartment. Thanks
