Volt display in ceiling cubby-hole
Bunty
Hi guys,
Can anyone help me, I’m looking into fitting a voltage display in my t6.1 up in the headlining where the blanking plate is . I’m sure I saw a post about something similar but can’t find it, has anyone else done this?
If so what volt display setup did you use?
would be nice to see what power my battery has left!
Have a look here...
Voltage alone will only help you approximate the state of charge. Better to read through the post above.
On the display, did you mean this;
I have been toying with the idea of hooking up this display to a Victron Smart Shunt. It would be exactly what you need. Can you wait 12 months? :)
Interesting , thank you guys and far more complicated than I was imagining!
it looks like the easiest option would be a victron smart shunt ( my dc-dc charger and solar are victron too) then I guess add a display . Although if it’s on an app on my phone that’s just as good ?
Thanks again !
Thanks again !
I wish the smart shunt had been available when I installed my kit, I wanted the tech to be fit, forget and out of sight mostly.
