Voltronic standby charger
awillyfootball
Hi I wonder if anyone could help. I have just purchased a Voltronic standby charger and I'm looking for help on how to install it. My current setup is 110ah agm battery with victron dc to dc charger and 200w solar with vicron mppt. I'm not sure which way to wire it up. Is best to go to dc to dc charger or mppt, any help would be appreciated. Thanks
Run a link to the Starter battery.
And the Board (leisure) battery.
Make sure you fuse the battery connection end.
If you have a dc-dc charger, then you can pic up both battery feeds there.
The unit has no negative connection so i assume your leisure battery would need to be common grounded to the vehicle for it to work properly
Most leisure batteries are grounded to the van but thought is was worth mentioning just in case
Lol
... Yes those boxes are basic diode, resistor droppers..no smarts.
All you need is a battery link.... With comon neg.
Here's a closer look...
