Vw Supplied Kenwood Sub
no seen that one yet . . . .
but id assume that it just has a QUAD-LOCK loop through that plugs in to the back of the radio/loom, (for power and signal)
so plug & play for the dealers to fit.
looks like this one: Subwoofers • KSC-PSW8 Features • KENWOOD Europe
Key Features
250W peak power
Powered subwoofer
20cm woofer
Aluminum Die-cast frame
Noise-less sound
Wired remote (Level/Freq./phase control)
Line(RCA) + speaker level input
Signal sensing power control
Speaker Features
Speaker System Active subwoofer system
Peak Input Power 250W
Speaker Size 200mm
Magnet Type Ferrit
Wired remote included Yes
Amplifier Included Built-in
Enclosure size (BxHxD) 350 x 75 x 240 mm
Enclosure net weight 4.5 kg
Amplifier Features
Maximum power output 250W
Low-pass Filter Yes
Phase inverter 0°(Normal) / 180°(Reverse) Yes
Power Indicator Yes
Line in RCA
Speaker level Input Yes
Chassis Aluminum Die-cast
DC cable Supplied Yes
Amplifier-Specifications
Maximum power output (4Ω) 250W x 1
Low-pass Filter 50~125 Hz
Frequency response (+0dB, -3dB) 35Hz ~ 150Hz
Operating voltage 14.4V (11V ~ 16V allowable)
Maximum current consumption 10A
Accessories
Remote control wired remote
DC cord 500 cm
Screws (Parker-type) Ø 5 x 16mm, 4 pieces
Screws (M-type) M4 x 6mm, 4 pieces
£189
Kenwood KSC-PSW8 Compact Under Seat Active Amplified Powered 250W Subwoofer
install book - Subwoofers • KSC-PSW8 Support • KENWOOD Europe
