VW T5 T6 SWB Amdro boot jump camping unit, wheel arch unit and matching boards to span the two units.
Used these item for the last 2 years to turn our T6 into a day van but have now had a full conversion so no longer required. All items are in excellent condition.
The units are manufactured from Structural Birch Plywood with a hardwearing heat pressed grey grip finish and semi-transparent white on the unit with the natural grain visible. Cut edges sealed with linseed oil, Plywood Grown and produced in Latvia.
Camping unit
Comprised of two side units link together and bolted down to the existing mountings in the floor. One unit has box storage, the other houses the cooker drawer with a Primus Tupike gas stove and 12 litre water container and pump tap.
Wheel Arch Unit
Storage and bench unit to go over wheel arch and bolts down to two existing lashing point positions already in the floor.
Both units come with longer fixing bolts, just remove the existing bolts, position unit, and bolt down securely. Can be installed and removed in less than 5 minutes.
Also include are two cushions, table and matching boards to span the two units. These provide a load space divider or sleeping platform.
£1000 No offers, collection only from North Lincolnshire
Products - Amdro Alternative Campervans
Camping unit
Wheel Arch Unit
