vw transporter t6.1 single passenger seat with auxiliary battery underneath, how to fit a swivel?
If the battery terminals are under the top of the base then you don't have an issue, otherwise, if you can (If the battery is suitable) lay it on it's side then fit the swivel as normal.
I’ve used the sportscraft swivel on mine (the leisure battery version which gives you a bit more clearance underneath). All you do is remove the seat from the seat base, bolt the swivel to the seat base and then bolt the seat to the swivel. The swivel normally comes with the required fixings (the sportscraft one I bought did anyway). It’s a pretty straightforward job to do to be honest.
I’ve attached some photos showing the seat base and then the swivel fitted on top.
Does that help? Link to the sportscraft base: Sportscraft VW T6 Passenger Side Single Seat Swivel Base - Leisure Battery Type 4033844005036 | eBay
