If nobody can help and you are able to remove the existing wheel bolts with your current key, it might be easier to source a new/second-hand set of locking bolts and key?
I've found one on eBay now so I'll delete this WTD if it turns up and is okay.
I could keep trying with my current key (I think it is the key rather than the bolts which is damaged) but I'd rather have a clean key rather than damage the bolts and be in a bigger issue. Unless there is a marked difference in the new key and existing bolt combo (i.e. there isn't lots of play in it), my plan is to remove the current locking bolts.
