Hey buddy , came across a thread that has a walk throo on how to install a washer fluid sensor ,go to page 2 and it is a very well righten ,near the end it has the module coding am sure , I don't have vcds so am not really clued up on how to work it , hopefully the thread helps you , is there a reason why you want to code it out , I have heard that some washer fluids affect the sensor and it believes it's empty when infact it's got plenty, if it's something like that then mibi try and just fill with water and see if the sensor is ok ,hope this has some help
I have all the bits just haven't had time yet, am planning to get them fitted over xmas break, just need to decide if I'm going to use the standard panels or put them in the new DRL panels ???
