Water Pressure On Sink
djcbilly
Hi all. I've only used my van a couple of times last year. When I turn the tap on it's barely dribbling out. Pump seems to be making its usual noise, so I'm thinking maybe scaled-up pipes? Any suggestions as to how to fix?
More likely to be a folded pipe/hose somewhere. Can you trace the full run from the pump to the tap to see if there is any damage or folding ?
Pete
I'm not sure about a Camper set-up, but cannot imagine it's much different to my Motorhome. When I have that exact symptom, it's always just down to the fact I drained the system right down the last time I use it, and it takes a while to prime the system.
