Hi,
I last turned on this heater (12v diesel) a year ago where it was working perfectly. However testing it today it's just blowing cold air.
The first time it was started up today the heater blew cold air and turned off after a few seconds, with error code f07. Realising this was the pump I disconnected the lead to the pump and reconnected it which seemed to fix it (I don't think I'd pushed it all the way in). The next few times the heater started up and stayed on with a good strong output of cold air, but I constantly got error f03. I checked the voltage from the heater and then at the fuse box and both showed 13.69v. Mostly the heater does stay on for a few minutes but then turns off on its own - however sometimes it starts and turns off after only a few seconds. Over the course of trying a few more times I got error f08 followed by f01, which seemed random. Then back to f03 which is the most consistent, but the voltage is fine.
One thing is I don't believe fuel is getting into the heater. However there is no blockage in the pipes (I have confirmed this), and the pump seems to be working fine (I also have a replacement pump which I've tried with no difference) - it clicks and when the output of the pump is disconnected the fuel is shooting out. With the pipe disconnected at the heater end (with heater switched on) fuel does not shoot out (should it?). Sometimes the pump stops clicking after a few seconds and other times it stays on.
One thing is the burner is never starting up. Why would this be? Because of the lack of fuel entering the heater?
Can anyone please offer any advice on what I can do as I am a bit lost?
Simon
Simon
