Webasto AirTop200
FranziAndrew
Hi all you knowledgeable people! So glad to have found this place
We have a webasto air top 2000 and can not by the life of us find the combination timer! It's in an older bus and we have looked everywhere for it but can't locate it. It currently doesn't blow hot air and the control element is blinking... does anyone have any ideas whether there should be a control timer? And if there isn't one, how could we figure out why it isn't working and what the blinking light means?
Thanks in advance for any help!
Some only have a temperature control. Could you upload a photo of your controller? That may assist in identification.
It always helps to say which model 2000 you have - there are 2000, 2000S, 2000ST and 2000STC models.
If you are saying that you have a rheostat controller ( the round dial ) you will not ( usually unless you have had some jiggery-pokery done by someone like me ) have anything else like a timer.
Your fault code is the number of slow flashes after the initial 5 rapid ones.
