Webasto aux heater
IrishT6
Hi all, I have a 2017 shuttle with factory webasto heater fitted, has anyone ever changed the igniter? Is it a straight forward job?
What model heater is it? Details are in door shut. Usually A-pillar.
What error code are you getting?
Conduct electrical test of glow
plug (see Section 5.7, Fig. 504,
Point 6):
Measure glow plug resistance on glow plug connector
X5 (white wire), also see Section 9.3.1
At 25 ± 5 °C:
0,235 to 0.355 ohms
Unfortunately you will have to remove the heater to replace the glow pin. It is usually advisable to replace the burner tube with burner pad at the same time if it has had a lot of use.
Also, sadly, I have sold out all my stock of Evo burners with glow pins - I was selling them off at half price.
  • webasto-thermo-top-evo-workshop-repair-manual.pdf
I do have a spare glow pin - used with minimal use, well within parameters at 0.273 ohms, I could let you have it for £50 if it is your glow pin that has failed ( very unusual occurrence ) :
