Webasto Aux water heater lock-out
hoobsbus
Using carista I have found the Aux heater is showing a lock out that can't be reset. I also tried the reset, engine running and pull fuse 11, this then shows loss of heater control in carista, this can be reset.
Any one had this, trip to VW I think.
What's the fault code?
Please post "Detailed ECU info"-report (under Carista Service menu).
Auxiliary heater:
00135 - Heater locked
00002 - No flame formation: after repeated start attempt
00056 - No flame formation: during initial start attempt
This was the export
Hmmm, the report should contain details about controller's software and hardware - to identify it properly. Perhaps it's beyond Carista's capabilities?
I will check in the morning if there is more info, Thanks
Just found the earlier thread, same codes -
Webasto Aux Heater Unlock​
Visit to the auto electrician fixed it (Webasto center), they struggled to connect to the Webasto diagnostics, believing it was something to do with VW coding or similar, they checked it over reset all errors, the next morning of cold weather it started to work, you can hear and smell it running under the passenger side of the van, it also got to running temp quickly.
Carista shows no errors.
