Webber Go Anywhere BBQ gas connection.
Ricardo T
Now or Never
T6 Legend
Hi All, So hoping to connect up my portable glass bbq to my vans underslung gas tank which already has a regulator attached. I have the the quick release male coupling to be attached to the hose for the 'van end' to connect up. Is the 'bbq end' male coupling available separately (the same thread as the top of the disposable cylinder) so I can make up a length of hose with these connectors on either end?
Would anyone know what size male thread it is and if that connector has a specific name?
Thanks all.
I've got the same barbecue, amazing bit of kit! We've only used it with the canisters but I looked at the adapters in the summer.. I think the canister fitting is called an EN417 type.
Let me know how you get on because I want to do the same at some point.
Thanks guys, I managed to come up with that EN417 fitting number too last night on tInternet...just got to find one or a hose with one on it....ill keep you posted.
If all else fails ill get the expensive Webber Adapter kit and cut the regular off which is not required.
Reactions: Jlo
