What size bit to remove this
Looks like a 10 or 12 spline - be very careful. I bought seat covers, had to find out what the arm rest bolt was, was told an 8mm Allen key fits, rounded off the bolt. Then found the correct tool (which wasn't easy) but it was too rounded off. So if I do need to remove my armrests, I'll need to saw or machine them off.
Find out for certain rather than guessing.
I will second that
I used a large star/torx to remove mine and mashed one up ended up cutting the plastic away to remove it with grips and had to replace the screw and plastic
Thanks will this do everything on the van I need to remove for carpeting, what about the seat belts?
