And some car wash shampoo stuff, if you do it often the brake dust doesn't build up.Bucket of water and a microfibre cloth are your friends!
Hi Guys, I'm getting some new alloys fitted in a couple of weeks and I'm just wanting recommendations on keeping them looking good.
Wheel woolies, cleaner and tyre dressings.
A ceramic coating before you fit the new wheels is the best money you can spend in making them easier to clean and keep them looking good. You can pick up an Autofinesse wheel ceramic kit from Halfrauds for about 25-30 quid I think. It's a doddle to apply and will make the wheels so much easier to clean. Just make sure the tyres are fitted before you apply the ceramic coating or the wheel weights won't want to stick very well.Hi Guys, I'm getting some new alloys fitted in a couple of weeks and I'm just wanting recommendations on keeping them looking good.
Agree with Chris, my wheels are intricate and we’re not easy to clean until I got my wheel woolies which make it much easier. As mentioned above I clean them on a different day than I wash Floyd. I also use a none chemical cleaner as below:A ceramic coating before you fit the new wheels is the best money you can spend in making them easier to clean and keep them looking good. You can pick up an Autofinesse wheel ceramic kit from Halfrauds for about 25-30 quid I think. It's a doddle to apply and will make the wheels so much easier to clean. Just make sure the tyres are fitted before you apply the ceramic coating or the wheel weights won't want to stick very well.
If you've got a wide spoke pattern with loads of room, you don't need wheel woolies, it's easy enough to get in there with a decent wash mitt. If they are narrower or more intricate then woolies or similar are a good idea.
Your clarification about the one you bought for your wheels cracked me up!!!I use an ikea 99pence bog brush, with a hole drilled in the screw cap on the top of the handle and a nut n bolt tightened through the handle cap
then just stick the bolt end in the battery drill, give the wheels a good smothering of shampoo and set about em
the ikea bog brush is absolutley useless as a bog brush, struggles to remove a decent residue , but plenty soft enough for a battery drill operated wheel brush
( i bought a new one for the wheels by the way )
I just can't picture my neighbours faces if they see me step outside with a bog brush on an electric drill! They'll be rolling around on the floor before they get to see whatYour clarification about the one you bought for your wheels cracked me up!!!
If you use gtehniq W6 instead of Bilberry (same concept fallout removal), it's meant to go with the C5 and actually reinvigorates the C5 properties. Worth noting that C5 only has an (unopened) shelf life of 1 or maybe 2 years, so you may well not get the full longevity of the coating with a 3 year old bottleI'm not sure what it would do to the C5 coating hence sticking to Bilberry at a strongish dilution and a decnt wheel wooly.
Thank you - thats some good advice. I'll look at the W6 as soon as I've used up the bilberry.If you use gtehniq W6 instead of Bilberry (same concept fallout removal), it's meant to go with the C5 and actually reinvigorates the C5 properties. Worth noting that C5 only has an (unopened) shelf life of 1 or maybe 2 years, so you may well not get the full longevity of the coating with a 3 year old bottle
